SAR110 and Gamespy Arcade and other games
I am having terrible problems getting GameSpy Arcade to work with my new ADSL equipment.
Before the ADSL stuff on my lovely 56k modem, I could use GSA fine, now with the ADSL equipment I can't. Now I have opened up all the needed ports for the GSA software and it still doesn't work.
I presume many other people use GSA and do online gaing through the SAR110, so can anyone walk me through how they managed to set it up to work? Thanks =)
BTW: I am using the SAR110 linked up to a hub and that links to 3 grogeous machines =)
Lorian
Re: SAR110 and Gamespy Arcade and other games
Try turning off Dos (Denial Of Service) protection in the Router.
This is a (small) but usefull site for the SAR-110 http://www.chrismarsh.co.uk/sar110/
And the solwise support forum at www.solwise.co.uk is excellent too.
Jc.
Thanks but no thanks =)
Thanks jc, but I have used both of these sites and thus far have not been able to fix my problem =)
Any other ideas - DoS protection has been turned off already btw =)
Lorian
Re: Thanks but no thanks =)
Have you increased maxsessip ?
What are the actual symptoms, and what is the firmware version in the 110?
Are you only connecting 1 or more computers?
Jc.
the_norris
I had the same problem to - well with e-mule.
First you need to increase the maxipses setting first - max I could set my router to was 500.
Also found that NOT using the filters to stealth the router but use NAT rules to forward to a IP not used on the LAN works better.
BTW My Firmware version is 1.38
Already Done
I have already increased teh maxipsess to the max of 500 and I am not stealthing the router at all at the moment and have all firewall protection down (no dont hack me) =)
Also firmware is latest one and I am using multiple machines.
Lorian
Re: Already Done
max value fo maxipsess is 512.
Try looking at this thread, it may help:
http://tinyurl.com/cchp
If this doesn't help you'll probably want to look at ZIPB (Zero IP Bridiging). See this site for set-up information :
http://www.chrismarsh.co.uk/sar110/zipb.asp
Jc.
