SAR110 Router Problem
My SAR110 Router crashes every time I try and get a server listing in MOH, Spearhead, Unreal Tournament / UT2003, WinMX (running as primary). Have tried all the 'fixes' on the solwise forums, but nothing helps.
Does anyone else have the problem or a fix?
Regards,
James Mayl
RE: SAR110 Router Problem
hi
I also have the same router and get UT server lists no problem - I use windows millenium and did not need any fixes - its not the router - must be your operating system !
best of luck
> Hi,
> Regards,
> James Mayl
I had this problem dissable the DOS protection in the firewall settings. Cured my problem with not being able to download the internet server lists.
