Running Tracert - Timeouts
Each time I run a tracert to any site, rather than all the hops being displayed it says they all time out, except for the final destination (see examples below).
Is this a fault soomewhere or a funny with my firewall or router ?
Browsing speeds seem fine but it is annoying when trying to diagnose faults !
Router is a Linksys HG200 and I'm using Kerio personal firewall on XP Pro (SP2).
Cheers for any assistance.
Tracing route to google.com [64.233.187.99]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 115 ms 110 ms 110 ms 64.233.187.99
Trace complete.
Tracing route to bbc.co.uk [212.58.224.131]
8 98 ms 27 ms 27 ms rdirwww-vip.thdo.bbc.co.uk [212.58.224.131]
Trace complete.
Tracing route to plus.net [212.159.8.137]
8 101 ms 33 ms 51 ms portal.plus.net [212.159.8.137]
Trace complete.
The_10th
Symptons look like you are connecting via a VPN. Have you tried disabling the firewall (Kerio) or tried pinging from the Linksys?
would appear the linksys is basicaly stopping the tracerout -- check to see if its blocking ICMP packets of certain sizes or anything, and try wiht the firewall disabled
The_10th
Hi
Just found out that your router quote '..TTL Expired in transit’ ICMP responses which hinders the use of traceroute..'
Link: http://www.chrisjames.me.uk/blog/_archives/2005/5/28/891895.html
Sad
