Routers - MSN - upnp - which one to buy?
Hi forum people,
I am about to get adsl and want to get a multiport router that I can use for gaming and MSN (audio and file sending/receiving)
Is there a router that works well with all of MSN? What router do people recommend?
Malc
[Moderators note (by Thomas): Seeing as this thread relates to ADSL hardware, it has been placed in the ADSL board.. that's where more people who can answer your question will be.]
I have used the D-Link 504 router on quite a few jobs and find it simple to set-up and configure and it offers decent security.
Sweetkid
Yeah the DSL-504 will cope with gaming & MSN's file-sharing and the like without any major problems. Mine doesn't want to work with ICQ though ( I haven't yet figured out just how to open the correct port in the firewall for the IP range required).
you might want to have a look at the Netgear DG814 (or DG824M for wireless). I use it and have yet to notice any real problems
Does MSN Messenger v6 not get round most of the NAT/firewall issues? I know it has worked for me at home behind my firewall. File transfer etc all work now whereas with version 5 or lower it didn't.
nry
Version 6 uses the correct IP address, where 5 didn't.
V6 still wont connect where NAT is in use on both ends, and no uPnP or forwarding has been setup.
I have looked into the Netgear DG814. ADSLguide review is good, easy setup, etc. The lastest firmware version supports upnp.
Thanks forum people, that will be my buy
Malc
hm... didn't know it supported upnp. i thought that the only useful thing the latest update did was to allow us to specify the MTU (i think they changed the default too)
[edit]ah yes, just installed the latest firmware version. interestingly it is now giving me Server Busy errors when i try to access the setup pages sometimes... this happening for anyone else?
