Router - what do I get?
TOTKO
Are there routers out on the market that will accept the USB connection from my Dynamode 360?
A friend in the States has a Netgear MR814 and he swears that his has one - but the UK model doesn't look to have from the pictures I've seen.
Do I need to buy a router with a built in modem? - I want to have WiFi.
You won't be able to use your USB modem with a router.
Whilst I don't know about the US router you describe, it's more
than likely a connection for a 'dsl' ethernet modem.
Your best bet is a combined router with modem.
Something like Netgear's DG834 which you could later add
a wireless access point, or an all in one modem / router / WAP
such as Netgear's DG834G.
Alec
TOTKO
Thanks.
I've been looking at that model. PC Plus magazine also rate it (this month)
