Router sync
Router sync
How can i find out what my router is syncing at?
Router sync
it is most likely in the manual that came with your router. if you'res still unclear, then if you post the manufacturer and model of your router there is bound to be someone here who will be able to advise you
Alecto
Router sync
You'll find it on google.
Just search using the make and model number and the word statistics, or stats.
Router sync
The following web page describes how to find line stats for many popular ADSL modems/routers:
http://www.kitz.co.uk/adsl/frogstats.htm
or tell us what equipment you have and we can tell you if it can show line stats.
