Router questions
Router questions
I just got a new to me router (handed down from my brother) and am trying to use it to replace my current Voyager USB Dial Up Modem.
I've sent a question to the guys at support, but haven't received a reply yet (ID: 2064260Cool, so I'll give this a go.
Now this router is originally from Switzerland, so I'm having to configuire all the settings manually. If anyone can help with this, that'd be great. There is some information on the PlusNet guide but there are still a few remaining options I'm trying to sort out.
This is the extra information required by this router.
Service Name (Possibly server name)
There are multiple PVC adaptors. Do I have to choose a particular one (PVC0 to PVC9)
Do I enable or disable bridge
What is the Annex Mode (requested in ADSL config)
Disable or enable Trelis (requested in ADSL config)
Handshake protocol (requested in ADSL config)
Wiring Selection: tip/ring or a/a1 (requested in ADSL config)
Bit Swapping, enable or disable (requested in ADSL config)
Is there anything else I should bear in mind when manually configuiring?
Any help hugely appreciated
Neeraj
Router questions
It would help if we had the model of the router are you sure its compatable with uk?
Router use strange terms and not all router use the same terms so it hard to tell without knowing the router
Service Name (Possibly server name) Anything you like
There are multiple PVC adaptors. Do I have to choose a particular one (PVC0 to PVC9) Any
Do I enable or disable bridge Disable
What is the Annex Mode (requested in ADSL config)ANNEX_A
Disable or enable Trelis (requested in ADSL config)Disable
Handshake protocol (requested in ADSL config)ppoa
Wiring Selection: tip/ring or a/a1 (requested in ADSL config)tip
Bit Swapping, enable or disable (requested in ADSL config)enable
Router model
The Router is a Devolo MicroLink ADSL Modem Router. It is originally from Switzerland. I've not been able to find out if it works here, but have emailed their tech guys.
Cheers for the help
Neeraj
