Router info ??
Router info ??
Hi all,
I've just joined Plusnet self install option and am thinking about getting a router instead of a modem.
I've been looking at the US Robotics Router 018000.
Has anybody got this router, and what do they think.
Any recommendtion for other routers would be much appreatiated.
Thanks.....
RE: Router info ??
Unless you are looking for any 'special' value added features, I would happily recommend the 'DABS Value' (see http:///www.dabs.com)ADSL router - quicklinx # 17P7WS (1 Eth Port) or 17P8WS (4 Eth Port). £60 and £68 respectively. [+VAT]
A router is defo the right choice as you'll be 'always on' regardless of the status of your PC. BTW - are you going static IP? Assuming the answer is yes...
RE: Router info ??
> Hi all,
> Thanks.....
Hi.
I don't know if this is the same model but a friend of mine said the US Robotics router is not very good as it does not allow port forwarding, which cause a problem say in in P2P file sharing. I have also just sined up and am thinking of getting the Netgear RP114 router.
RE: Router info ??
I have used two routers succesfully, both from Solwise Ltd (www.solwise.co.uk):
The SAR703 (£69 ex VAT)an ADSL ethernet router with one ethernet port (so you need a hub/switch to share it). It works well with no problems, and stays on all the time.
The SAR715 (£105 ex VAT)an ADSL ethernet router with four ports, AND in-built firewall. I've only just got it for this new ADSL connection. It set up easily enough.
Solwise are very helpful indeed. They are a small company, and you can actually get to speak to somebody if you run into problems with the set-up.
Trystan
RE: Router info ??
RP 114 is a router only and still needs a dsl modem to connect to net - I use Netgear DG814 modem/router/switch which works fine
RE: Router info ??
I have used the Draytek Vigor 2600 router and the Vigor 2200 USB router, both perform well and incorporate a firewall. They also have a VPN option that will allow you to dial into your own network from a remote PC. Very good value for money and very flexible. Can be purchased online from www.seg.co.uk the Vigor 2600 costs £179 +VAT check out the full specs at the same website.
> Hi all,
> Thanks.....
RE: Router info ??
Really? Damn... oh well good thing i havn't bought it yet. Could you tell me where you bought your DG814 from and how much it cost?
RE: Router info ??
Action.com - £99.99 plus vat and delivery - but they're waiting for new stock and hve increased the price slightly !
RE: Router info ??
Could you give me some information about the DG814? How good is the URL blocking as a parental control tool? How do you set this up and is it worth paying extra money for?
RE: Router info ??
By the postings in news:uk.telecom.broadband, it appears every retailer is in the same boat! It would be easier to get hold of a hen's tooth than a DG814 at the mo. Smiley
Slàinte!
Al
[ADSL Home self-install + Asus 6000EV]
RE: Router info ??
Have a look at the ASUS AAM6000EV; can be bought from Solwise for about £90 inc VAT. I agree with someone else's post; Solwise are small and helpful and are generally competitive pricewise.
