Router diagnostics ATM ping ???
Hey PN,
I apparently have been since April on the LLU pilot scheme. Since then i've had nothing but an awful connection. Needless to say i'm already talking to you about that...
My question is:
On my Router i can conduct diag tests. All the test PASS except two tests as follows...
Test ATM OAM F5 segment ping: FAIL
Test ATM OAM F5 end-to-end ping: FAIL
Is it a case that PN do not support this feature therefore the tests are not PASSing or could it signify a fault somewhere?
Cheers
J
Today at 0900 hours. I'm suppossed to receive 4.5 mbps
Moderators note by John (johnessex) All capital titles made Lower case. See the Link:rules
Unlike BT, the way I understand it is ATM is not used on Tiscali backhaul. I think Tiscali use IP/MPLS, this is why your ATM diagnostics fail.
Thanks.
