Router advice
Router advice
I recently lost my D-Link 504T during a thunder strorm, so I'm looking for a new router. I was thinking of getting a wireless router that also had four good old RJ45 sockets as well - do they make these? if they don't I'll probably just get a normal router.
Which routers do you guys think are reliable, good value for money?
cheers
Owen
mineview
Router advice
Netgear 834G, 834GT or 834PN dependinging on how thick your walls are and what wireless range/speed you are looking for.
Router advice
D-Link also do a G604T which is the same as your old 504T but has wireless in addition to the 4 cat5 cable ports.
In fact thats what I'm using to reply with. Smiley
Router advice
anything by Cisco for the SMB (cisco 837/877)
Router advice
Thanks for the advice guys. Much appreciated!
