Router Settings
Router Settings
Is there a list of Router setting in the forum or on the web site.
I'm looking for stuff like, LLC or VC, PPPoA or PPPoE etc.
I have a Linksys WAG354G.
Thanks in advance.
Router Settings
Does it have a setup wizard on the router itself or included S/W. this will auto-detect the settings for you.
You need:
VC
PPPoA
VPI 0
VCI 38
All explined in the help & Support page here.
Router Settings
Do these settings work for 8Mb DSL Max?
Router Settings
They have nothing to do with the speed. They are needed to establish an ADSL connection with the exchange.
The router will auto-negatiate the best sync speed when on a Max connection or sync at the speed the exchange states when on a non-max connection.
