Router Settings Correct?
I'm helping a friend set up his ADSL Router. He has lost his ADSL settings info and his password and is having problems contacting his ISP for support.
Would anyone mind confirming that I have set the following to the correct settings (then we would know tthat he problem is the password):
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
QoS Type: UBR
Pcr Rate:
Scr Rate:
Autodetect: Enable
Virtual Circuit: 0 VPI
38 VCI
DSL Modulation: MultiMode
Many thanks
ID
Re: Router Settings Correct?
that will work i think but G.D.M.T is what it should be.
Defo set it to G.DMT!
Many thanks for your help.
