Rocket scientist
Rocket scientist
So how come I can only access the Plusnet website. I have altered my MTU settings in the past but to no avail, cannot get to any other web sites. I can get my email. It is very intermittent connections as it was all right after 8.00 PM last night.
I don’t need to be a rocket scientist to able to use my ADSL connection with Plusnet; all I need is something nice and simple such as dial up! But I am paying for the convenience off ADSL but not getting the service. It is a waste of time reporting a problem as eventually, back comes some lame excuse from an overworked Plusnet staff member.
If I wasn’t leaving the country early in the new year I would have left Plusnet by now and found a more reliable ISP
RE: Rocket scientist
You dont give any details of O/S equipment or what the problem is so there is little we can do to help. Everyone is changing there MTU as a magic cure but get this bit wrong and it will stop you connecting. test your MTU http://www.dslreports.com/tweaks
get BT MTU setting prog here.
http://speedtest.btopenworld.com/mtu/
Tweaking may fix
Slow download speeds
Download slower than upload speed
Skipping in TCP streaming video/audio
Blank web pages
Connection issues to some sites
Tweaking will not fix
Packet loss
Multiplayer games over UDP
Your ping time
Regular PC freezes
Inherited hair loss
> Tweaking may fix
> Blank web pages
> Packet loss
> Your ping time
> Regular PC freezes
> Inherited hair loss
> > I am using Windows XP, and its back and running at normal speed now at 14.27.
I just don't get it ? is it Plusnet ?.
Have you checked
http://www.adslguide.org.uk/
A lot of Exchanges have been having problems maybe you are on one of them.
shellsong
Are you sure you've configured everything right? Have you got your DNS settings configured correctly?
Try visiting http://www.google.com then try visiting http://216.239.39.100/ if the second one works and the first doesn't then it's a problem with your DNS settings.
I stumbled across Web weirdness in PC advisor Feb 2003. Had to go to Internet Explorer and select Java logging enabled. And hey presto I'm back to full speed
