Reverse DNS is actually my log in name
Karmik
So, I thought I try some new software out on shields up, and shock horror, my dns is actually my log in name. Any way of getting this changed to a good old fashioned ip address? If I knew this, I'd have never used my real name for a log in when signing up.
Yes, this is standard with PN, you can however change it.
If you follow the ticket wizard, there is an option to change your rDns entry within the wizard and you will be given a number of possible options to select, one of which will be your IP address.
Karmik
Thanks mate, I'll check it outSmiley
where do you find the "ticket wizard" to change rDNS.
thanks
Hi and welcome to the forums,
Follow this Link
Karmik
Works a treat:
But it went off the shields up quicker than a proper whois search, which despite giving that ip still resolved it as me. Still 48 hours after the ticket was raised, and even that was put right.
