Reverse DNS, and more static ips
With my last isp i was given a block of 5 usable IPS, do plusnet currently offer this? And can i control the reverse DNS of the 1 static ip i have?
1 REPLY
Yes and yes.
For the first, raise a contact us ticket explaining you need a block of 8 IPs (which gives you 5 usable) and why you need them. You will then be given a RIPE form to fill in. You do need a good reason why you can't use NAT though.
Use the following route through contact us:
• Technical Support -> • Static IPs, IP Block Requests and Reverse DNS Setup -> • Request an IP Block
For the second, again raise a contact us ticket via the following route:
• Technical Support -> • Static IPs, IP Block Requests and Reverse DNS Setup -> • Change my Reverse DNS (PTR) configuration
