Resetting D-Link 504
I thought this may be of interest for users of the D-Link device.
As it states in the support pages on this portal, there is no reset switch on the D-link and if like me you have forgotten what you altered the user name and password to then you have a problem should you wish to access the device.
I contacted D-Link who told me the following.
1. Connect the 9 pin cable to the D-link and Coms1 of your PC.
2. Call up Hyperterminal from Start-accessories-communications.
3. make a new connection
4. Set Speed to 9600
5. type in flashfs cat inituser
You will now be given a list of settings and will be able to see the current username / password.
The above is for Win 98 but will probably be similar for other windows systems.
Support may wish to add this to the support page for this device?
Roll eyes
Regards
http://www.hmrg.co.uk
