Red Frog and 1 or 2 Mb?
Folks
Came over from BT with their red frog in tow and would love to upgrade my speed from 512kb.
Does anyone know if the old Red Frog supplied by BT can support the higher speeds please on Plusnet?
TIA
Tom B
Never heard of a red frog - perhaps this is a green frog that has been angry too long being connected to BT Wink
Any clues as to the make/model - any labels on it. Any names in the software your using with it?
I know most of the current models (including the green frog) will work at 2Mbs and most upto 8Mbs but I also know some of the original ADSL equipment only works upto 1Mbs.
labelled as Thomson Speedtouch 330, supplied by BT May 2003.
Cloudmaster
Is this the one? Bumph says it will do 8Mb/s downstream
http://www.alcateldsl.com/prod330.htm
many thanks Cloudmaster, that's my baby. Different colour but right model.
High speed here I come......................
