Recommend a proxy for me
I am having trouble getting a proxy server application to distribute internet on my LAN. At the moment the LAN is running on ICS but I would like to control the bandwidth to each machine.
I am running windows xp pro with AccessRunner ADSL modem software but none of the proxies I tried could find the internet connection.
Can anyone recommend a proxy app that will work with the plusnet package?
Cheers
RE: Recommend a proxy for me
If you are using a lan then you should have a router which makes life a lot easier.
I have used winproxy in the past on lans and it work fine get a free demo http://www.winproxy.com/
It has filtering built in and antivirus, and it logs all usess so you can collar anyone downloading mp3's
> Cheers
I am using a free version of AllegroSurf which works as proxy server between 5 home PCs on an old thin ethernet LAN and the 3Com 612 router from PlusNet and their ADSL line. It has worked fine for 3 weeks though I still haven't fully cracked the way to get send and retrieve emails through it.
AllegroSurf is at http://www.rhinosoft.com/
