Random Router Disconnection
My router seems to disconnect randomly. I have to go into the setup web interface, save the setting and the router resets, before it will reconnect.
Two questions:
1) Should it disconnect at all, unless I ask it to?
2) How should I be making it reconnect? Going into the setup and reseting the router doesn't seem like the correct way.
1 REPLY
RE: Random Router Disconnection
> Two questions:
All routers have a setting to disconnect after a period of inactivity. You can change this to 'always on' and I presume you have done this. If you have it sounds as though you may have a faulty router.
Most router suppliers / manufacturers have support forums that may well document your problem, it may be worth trying one of those.
