Random ADSL disconnections...
This ones been bugging me for a while now.
Randomly, at least once a day, my ADSL connection will go down for no reason. It can take anywhere between 5 minutes and a day to reconnect. I'm currently using a Bewan PCI ADSL modem on a linux box and get the error message 'Uncompatible Line Condition'. I have also tried the Dabs PCI ADSL modem on both windows and linux boxes, as well as a standalone ADSL Router/Modem. I get the same results with both.
I have been getting this problem for months now.
I will post more detail from the linux log when I get home from work.
Andy
for the last half an hour mines just been dropping every 2 mins, beginnign to get on my nerves now.
join the drop-out club fellas its FREE so why you moaning,and your garenteed agro for a week ,maybe two ,good uh Wink ...lol
look in the other thread at my troubles also about these random drop outs>>
thread:::: Random disconnects?? How many are there of us? Post here.
Not sure if this is the same problem that other people have been having. I searched through many forums to see if any one was having similar disconnection problems and besides actually getting disconnected I found nothing. Its getting more and more annoying everytime I lose connection and just watch my linux router complaining about 'Uncompatible Line Conditions' and 'Spurious ATU Detected'. I thought I'd post a bit of the log incase its useful.
Jan 18 17:47:33 router kernel: aal5_decode: crc check failed!
Jan 18 17:47:55 router kernel: unicorn_msw: Bringing down line due to persistent:
Jan 18 17:47:55 router kernel: unicorn_msw: NEAR_LOS = 5/NEAR_LCD = 5/NEAR_LCDI = 0
Jan 18 17:47:55 router kernel: FAR_LOS = 0 FAR_LCDI = 0 FAR_LCDNI = 0
Jan 18 17:47:55 router kernel: unicorn_pci: AMU_EVENT_SHUTDOWN
Jan 18 17:47:58 router kernel: unicorn_pci: AdslStatus=2
Jan 18 17:47:58 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:47:58 router kernel: unicorn_msw: Current Modem State (0): IDLE
Jan 18 17:47:58 router kernel: unicorn_pci: MSW state: IDLE
Jan 18 17:48:00 router fcron[27127]: Job /sbin/iptables -L -v -n > /home/httpd/html/iptables.txt started for user root (pid 27129)
Jan 18 17:48:00 router fcron[27128]: Job /sbin/iptables -L -v -n -t nat > /home/httpd/html/iptablesnat.txt started for user root (pid 27130)
Jan 18 17:48:03 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:48:03 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:48:03 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:48:03 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:48:04 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:48:04 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:48:09 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:48:09 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:48:12 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:48:16 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:48:16 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:48:16 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:48:26 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:48:26 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:48:27 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:48:27 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:48:27 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:48:27 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:48:31 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:48:31 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:48:34 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:48:39 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:48:39 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:48:39 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:48:49 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:48:50 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:48:50 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:48:50 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:48:50 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:48:50 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:48:50 router pppd[24797]: No response to 3 echo-requests
Jan 18 17:48:50 router pppd[24797]: Serial link appears to be disconnected.
Jan 18 17:48:50 router snort: pcap_loop: recvfrom: Network is down
Jan 18 17:48:50 router snort: Final Flow Statistics
Jan 18 17:48:50 router snort: Snort exiting
Jan 18 17:48:51 router ipcop: PPP has gone down on ppp0
Jan 18 17:48:51 router dnsmasq[27162]: started, version 2.17 cachesize 150
Jan 18 17:48:51 router dnsmasq[27162]: read /etc/hosts - 3 addresses
Jan 18 17:48:51 router dnsmasq[27162]: reading /var/state/dhcp/dhcpd.leases
Jan 18 17:48:51 router dnsmasq[27162]: reading /var/ipcop/red/resolv.conf
Jan 18 17:48:51 router dnsmasq[27162]: using nameserver 212.159.13.50#53
Jan 18 17:48:51 router dnsmasq[27162]: using nameserver 212.159.13.49#53
Jan 18 17:48:54 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:48:54 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:48:56 router pppd[24797]: Connection terminated.
Jan 18 17:48:56 router pppd[24797]: Connect time 212.2 minutes.
Jan 18 17:48:56 router pppd[24797]: Sent 966526 bytes, received 16239831 bytes.
Jan 18 17:48:56 router pppd[24797]: Exit.
Jan 18 17:48:57 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:48:57 router red: Connectioncheck: will connect again
Jan 18 17:48:58 router ipcop: Dialling PlusNet.
Jan 18 17:48:58 router red: BEWAN ADSL: Loading unicorn_pci_atm, Modulation=AUTO, may take time to uncompress...
Jan 18 17:49:00 router fcron[27234]: Job /sbin/iptables -L -v -n > /home/httpd/html/iptables.txt started for user root (pid 27236)
Jan 18 17:49:00 router fcron[27235]: Job /sbin/iptables -L -v -n -t nat > /home/httpd/html/iptablesnat.txt started for user root (pid 27237)
Jan 18 17:49:01 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:49:01 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:49:01 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:49:12 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:49:12 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:49:12 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:49:12 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:49:12 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:49:12 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:49:16 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:49:16 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:49:19 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:49:24 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:49:24 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:49:24 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:49:35 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:49:35 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:49:35 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:49:35 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:49:35 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:49:35 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:49:39 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:49:39 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:49:42 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:49:47 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:49:47 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:49:47 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:49:58 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:49:58 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:49:58 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:49:58 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:49:58 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:49:58 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:50:00 router fcron[27540]: Job /usr/local/bin/timecheck > /dev/null 2>&1 started for user root (pid 27544)
Jan 18 17:50:00 router fcron[27541]: Job /usr/local/bin/makegraphs >/dev/null started for user root (pid 27545)
Jan 18 17:50:00 router fcron[27542]: Job [ -f "/var/ipcop/red/active" ] && /usr/local/bin/setddns.pl >/var/log/dynupdate.log 2>&1 started for user root (pid 27547)
Jan 18 17:50:00 router fcron[27542]: Job [ -f "/var/ipcop/red/active" ] && /usr/local/bin/setddns.pl >/var/log/dynupdate.log 2>&1 terminated (exit status: 1)
Jan 18 17:50:00 router fcron[27543]: Job /sbin/iptables -L -v -n > /home/httpd/html/iptables.txt started for user root (pid 27550)
Jan 18 17:50:00 router fcron[27549]: Job /sbin/iptables -L -v -n -t nat > /home/httpd/html/iptablesnat.txt started for user root (pid 27552)
Jan 18 17:50:02 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:50:02 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:50:05 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:50:10 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:50:10 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:50:10 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:50:21 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:50:21 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:50:21 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:50:21 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:50:21 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:50:21 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:50:25 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:50:25 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:50:28 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:50:29 router ipcop: ERROR: Bewan ADSL failed to start
Jan 18 17:50:33 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:50:33 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:50:33 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:50:35 router red: Connectioncheck: fail before pppd start : no sync, trying again
Jan 18 17:50:36 router red: BEWAN ADSL: stop
Jan 18 17:50:38 router red: BEWAN ADSL: cleanup
Jan 18 17:50:38 router kernel: unicorn_msw: ATU_R is DOWN
Jan 18 17:50:38 router kernel: unicorn_msw: Modem going to IDLE
Jan 18 17:50:39 router kernel: unicorn_pci: driver removed
Jan 18 17:50:39 router ipcop: Dialling PlusNet.
Jan 18 17:50:39 router red: BEWAN ADSL: Loading unicorn_pci_atm, Modulation=AUTO, may take time to uncompress...
Jan 18 17:50:52 router kernel: PCI: Found IRQ 12 for device 00:09.0
Jan 18 17:50:52 router kernel: PCI: Sharing IRQ 12 with 00:04.2
Jan 18 17:50:52 router kernel: unicorn_pci: AFE 70134
Jan 18 17:50:52 router kernel: unicorn_pci: v 0.8.6, 22:37:08 Dec 14 2004
Jan 18 17:50:52 router kernel: unicorn_pci: MSW parameters:
Jan 18 17:50:52 router kernel: ActivationMode=3
Jan 18 17:50:52 router kernel: ActTimeout=300000
Jan 18 17:50:52 router kernel: AutoActivation=1
Jan 18 17:50:52 router kernel: DebugLevel=0
Jan 18 17:50:52 router kernel: DownstreamRate=8128
Jan 18 17:50:52 router kernel: unicorn_pci: ExchangeDelay=20
Jan 18 17:50:52 router kernel: FmPollingRate=1000
Jan 18 17:50:52 router kernel: g_RefGain=28
Jan 18 17:50:52 router kernel: g_Teqmode=7
Jan 18 17:50:52 router kernel: InitTimeout=20000
Jan 18 17:50:52 router kernel: Interoperability=0
Jan 18 17:50:52 router kernel: unicorn_pci: LCD_Trig=15000
Jan 18 17:50:52 router kernel: LOS_LOF_Trig=5000
Jan 18 17:50:52 router kernel: LoopbackMode=0
Jan 18 17:50:52 router kernel: MswDebugLevel=2
Jan 18 17:50:52 router kernel: RetryTime=5000
Jan 18 17:50:52 router kernel: TrainingDelay=120
Jan 18 17:50:52 router kernel: unicorn_pci: useRFC019v=0
Jan 18 17:50:52 router kernel: useRFC029v=7000
Jan 18 17:50:52 router kernel: useRFC040v=0
Jan 18 17:50:52 router kernel: useRFC041v=1
Jan 18 17:50:52 router kernel: setINITIALDAC=93
Jan 18 17:50:52 router kernel: unicorn_pci: useRFCFixedRate=1
Jan 18 17:50:52 router kernel: useVCXO=0
Jan 18 17:50:52 router kernel: _no_TS652=0
Jan 18 17:50:52 router kernel: unicorn_pci: driver parameters: DebugLevel=0
Jan 18 17:50:52 router kernel: unicorn_msw: FmPollingRate=1000ms,InitTimeout=20000ms,ActTimeout=300000
Jan 18 17:50:52 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:50:52 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:50:52 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:50:52 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:50:52 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:50:56 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:50:56 router kernel: unicorn_msw: Modem Init Failure: Spurious ATU Detected (25)
Jan 18 17:50:56 router kernel: unicorn_pci: MSW failure: SPURIOUS ATU DETECTED
Jan 18 17:51:00 router fcron[27823]: Job /sbin/iptables -L -v -n > /home/httpd/html/iptables.txt started for user root (pid 27825)
Jan 18 17:51:00 router fcron[27824]: Job /sbin/iptables -L -v -n -t nat > /home/httpd/html/iptablesnat.txt started for user root (pid 27826)
Jan 18 17:51:07 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:51:07 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:51:07 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:51:07 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:51:07 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:51:07 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:51:11 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:51:11 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:51:14 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:51:18 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:51:18 router kernel: unicorn_msw: Modem Init Failure: Message Error (20)
Jan 18 17:51:18 router kernel: unicorn_pci: MSW failure: MESSAGE ERROR
Jan 18 17:51:29 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:51:29 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:51:29 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:51:29 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:51:29 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:51:29 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:51:33 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:51:33 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:51:36 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:51:41 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:51:41 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:51:41 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:51:51 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:51:51 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:51:51 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:51:51 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:51:51 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:51:51 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:51:53 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:51:53 router kernel: unicorn_msw: Modem Init Failure: Spurious ATU Detected (25)
Jan 18 17:51:53 router kernel: unicorn_pci: MSW failure: SPURIOUS ATU DETECTED
Jan 18 17:52:00 router fcron[28087]: Job /sbin/iptables -L -v -n > /home/httpd/html/iptables.txt started for user root (pid 28089)
Jan 18 17:52:00 router fcron[28088]: Job /sbin/iptables -L -v -n -t nat > /home/httpd/html/iptablesnat.txt started for user root (pid 28090)
Jan 18 17:52:03 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:52:03 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:52:03 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:52:03 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:52:03 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:52:03 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:52:07 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:52:07 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:52:10 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:52:15 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:52:15 router kernel: unicorn_msw: Modem Init Failure: Uncompatible Line Conditions (5)
Jan 18 17:52:15 router kernel: unicorn_pci: MSW failure: UNCOMPATIBLE LINECONDITION
Jan 18 17:52:23 router ipcop: ERROR: Bewan ADSL failed to start
Jan 18 17:52:25 router kernel: unicorn_pci: AMU_EVENT_RETRY
Jan 18 17:52:25 router kernel: unicorn_pci: AdslStatus=1
Jan 18 17:52:25 router kernel: unicorn_msw: Current Modem State (3): ACTIVATING
Jan 18 17:52:25 router kernel: unicorn_pci: MSW state: ACTIVATING
Jan 18 17:52:26 router kernel: unicorn_msw: Event Reported (3): Initializing
Jan 18 17:52:26 router kernel: unicorn_pci: MSW event: TO INITIALIZING
Jan 18 17:52:30 router kernel: unicorn_msw: Current Modem State (6): INITIALIZING
Jan 18 17:52:30 router kernel: unicorn_pci: MSW state: INITIALIZING
Jan 18 17:52:32 router red: Connectioncheck: fail before pppd start : no sync, trying again
Jan 18 17:52:32 router red: BEWAN ADSL: stop
Jan 18 17:52:33 router kernel: unicorn_msw: useRFCFixedRate (1) ENABLED: deactivate the RA mode in DMT mode
Jan 18 17:52:34 router red: BEWAN ADSL: cleanup
Jan 18 17:52:34 router kernel: unicorn_msw: Performing disorderly shutdown!!!
Jan 18 17:52:34 router kernel: unicorn_pci: AdslStatus=0
Jan 18 17:52:34 router kernel: unicorn_msw: Current Modem State (0): IDLE
Jan 18 17:52:34 router kernel: unicorn_pci: MSW state: IDLE
Jan 18 17:52:34 router kernel: unicorn_msw: Modem going to IDLE
Jan 18 17:52:35 router kernel: unicorn_pci: driver removed
Hope its not too long Smiley
