Rain and Broadband
Rain and Broadband
Could someone technical explain the link between rain/bad weather and poor broadband speeds. Cheers
Plusnet Staff
Plusnet Staff
Fixes: 159
Rain and Broadband
This blog was posted because of the recent problems.
These conditions can have severe effects on the noise of a signal and have a significant attenuative effect on a broadcast signal.
An example, is when your sky signal goes dead during a heavy storm, admittedly the signal is much higher in frequency and lower in power but you get the idea.
 Chris Parr
 Plusnet Staff
Fixes: 57
Rain and Broadband
Link doesn't work
Plusnet Staff
Plusnet Staff
Fixes: 159
Rain and Broadband
Works for me, what does it do for you?
http://community.plus.net/comms/2007/06/25/it-doesnt-rain-but-it-pours/
 Chris Parr
 Plusnet Staff
Fixes: 57
Rain and Broadband
I get this response
Uh oh!
Sorry, we couldn't find the page you requested. Please use the search form to find what you're looking for.
Is this the link http://community.plus.net/csc/2007/06/25/its-raining-its-pouring/
Plusnet Staff
Plusnet Staff
Fixes: 159
Rain and Broadband
Try that link again please, it looks like James had pressed a random button when he wrote it Cheesy
 Chris Parr
 Plusnet Staff
Fixes: 57
Rain and Broadband
Yup - works now Cheesy
James
Rain and Broadband
Apparently guilty as charged although I don't know what I did!
Rain and Broadband
thanks , i get rain interfering with transmissions but how does rain (obviously excluding submerged equipment) make broadband slow.
Fixes: 57
Rain and Broadband
It gets into exposed joints and reduces the noise margin and increases the error rate.
I am just waiting for everything to dry out and get back to normal.
Upstream speed is presently 224kbps with a noise margin of 6dB (normal when it's dry is 448kbps at 20dB)
Plusnet Staff
Plusnet Staff
Fixes: 159
Rain and Broadband
As holtlane says the moisture can get into joints and cause problems such as speed reductions or intermittent connections due to the change in noise margin.
 Chris Parr
 Plusnet Staff
p_w_d_stone
Rain and Broadband
Submerged equipment is a major factor, but AFAIK it's mostly down to the water causing small shorts and/or cross-connections on the copper wires that carry the broadband to your house. I've heard of a number of cases where users are able to hear hissing or neighbour's conversations, but only when it's wet. These faults can often be difficult to prove as inevitably the BT engineer arrives when it's dry and the fault isn't present.
If you dial 17070 option 2 on your phone then you'll get a quiet line test - this should be absolutely silent, without hisses, crackles, beeps, or your neighbours. Anything you can hear during that test will almost certainly adversely affect your broadband connection.
Another possible factor is the electromagnetic interference from storms increasing noise on the line.
Lastly, and completely non technical, if it's bad weather more people work from home or stay in of an evening- meaning VPN and web traffic is increased- and leaving less capacity to go around.
Rain and Broadband
I have been checking my adsl to see how the weather effects it as you can see there is nothing that jumps out at you and so far I would say it makes no difference to me at least. More than rain temp could be a factor as the wires expand contract which may have a effect
22/05/07 5056 ds 8
23/05/07 5088 ds 9
24/05/07 5024 ds 9
25/05/07 4960 ds 10
26/05/07 5056 ds 5
27/05/07 4992 ds 5 Wet
28/05/07 4992 ds 8 Wet
29/05/07 5056 ds 5 Wet
30/05/07 5024 ds 8
31/05/07 4960 ds 8
1/06/07 5152 ds 10 hot day
2/06/07 4960 ds 9 hot day
3/06/07 4928 ds 10 hot day
4/06/07 4992 ds 10 hot day
5/06/07 4832 ds 10 hot day
6/06/07 5024 ds 9 hot day
7/06/07 4928 ds 9
8/06/07 4928 ds 10
9/06/07 5024 ds 9 hot
10/06/07 4960 ds 9 hot
11/06/07 4992 ds 11 hot
12/06/07 4992 ds 9 hot
13/06/07 4864 ds 11 hot
14/06/07 5024 ds 9 Wet
15/06/07 4992 ds 10 Wet
16/06/07 4960 ds 10 Wet
17/06/07 5024 ds 11 dry
18/06/07 4992 ds 10
19/06/07 5024 ds 9
20/06/07 5024 ds 11
21/06/07 4864 ds 10
22/06/07 5056 ds 9
23/06/07 5024 ds 9
24/06/07 4992 ds 9
25/06/07 4992 ds 9
26/06/07 4992 ds 10
pacem
Rain and Broadband
I only have problems after rain. The trouble is that even a daily reading of rain is not enough:
Last weekend (June 16th) there was a downpour that upset my ADSL.
http://portal.plus.net/central/forums/posting.php?mode=reply&t=57038
The trouble is the rain reading is at 9am so errors can appear before the reading.
Also sudden rain for me is worse than constant rain. I know that most of the 12mm recorded on Thurday morning fell on Wednesday lunch time.
(Note the router can get stuck after a low upstream SNR and I was on holiday from Saturday so those readings are un-qualified.
Curiously after the rain this week ...
http://ccgi.pacem.plus.com/router.php?days=7&day=27&month=6
...I've not had a problem because although Monday and Tuesday had the same amount of rain as the previous example, the rain was constant throught the day.
If your upstream SNR and sync drop (as mine do) I think it would suggest the problem is at the exchange end as the weak received signal would be even weaker with comparibly more interference, whereas the signal being sent would be relatively stronger than any interference and hence not affected.
Paul.<><
PS. Pages posted require SVG which is a plugin from adobe or it's built-in to FireFox.
dennisb66
Rain and Broadband
Thanks for that BT test number Peter,I gave it a try and was pleased to hear absolutely nothing.Will let all my friends know about it. :lol:
