Radmin
Radmin
I use Radmin from famatech to connect to and control another computer that I have. It's like Remote Desktop.
In the mornings I can connect fine, and its almost useable, that is - when I click I can see a reponse pretty much straight away. However, come the afternoon and evening if it connects at all, it will be a round trip of over a minute, that is, when I click it is a minute before there is a response.
Does anyone know why? Can anyone offer any suggestions for improving? Thanks.
1 REPLY
Radmin
I'd raise a ticket to support straight away, with the ports that
Radmin uses. They will then be able to create a profile for the Ellacoyas, which are slowing your software down during peak hours.
