REN Ratings
dsmail
REN Ratings
Sorry if this is in the wrong forum for starters. Sharing with my adsl, I have 3 phones and an answering machine on a standard domestic setup where it all works fine. One of my phones is a cordless GAP compatible type and I want to add another extension to this phone. My only problem is that if this extra phone (unpurchased as yet) has a REN rating of 1 or more, then my total REN will shoot up to 5 when 4 is the limit. Do most gap compatible base stations only count as REN 1 no matter how many phones are registered to the base station, or does each extension phone normally carry a REN rating of it's own. Not been able to find this info on web. Perhaps it varies from make to make. I have a BT Verve 3010 and I want to add / register another to the existing base station. Will my REN be increased.
Any ideas?
Dave
wandelaar
REN Ratings
Yes it is the base station for the cordless phones that the BT network 'sees', and most have a REN of 1.
Beware if you use a wireless network that it is not unknown for dect phones to upset the network as they share a common or similar radio frequency.
Hope this helps.
regards
Dave
REN Ratings
REN is a property of the phone line, rather than anything wireless. It signifies how much power a phone set draws to make it ring, in an easy to count number.
They only count towards phyicaly attached devices.
In otherwords, only the base-station counts towards the REN value. You can have as many cordless attachments, as the base-station allows.
dsmail
REN Ratings
Thanks for your detailed replies. That's exactly the info I needed.
Dave
