RE FastTrack Upgrade
@ palmer934,
That's Right, you can pay £14.99 to move to a 2MBIT ASAP without waiting
Cant regrade my account
k, So I click connection settings -> upgrade account -> bb premier 30gb (monthly) and click go.
That takes me to a 'contact us/help wizard' page which says I have to click on 'Broadband Upgrade Request' at the bottom.
That link takes me back to the Plus.net homepage.
What am I supposed to do - is there a problem because I'm going from one £21.99/m package ( ADSL Home Self-Install) to another?
RE: Upgrading from £21.99 a month
@ palmer934
You don't have to upgrade if your monthly fee is £21.99 all inclusive
When BT decide to give you the speed increase it will be free of charge, When FUP is put inplace fully.
You will be automatically switched to 30GB @ £21.99 a month
Is this the same problem as in this thread?
Yeah same prob, cheers.
I understood that if I pay a bit I can get the upgrade done earlier, is that not right?
