Quick Router Question
Any one happen to know make and model number of the routers that Plusnet is sending out with the starter packs.Just want to make sure that when it arrives I have it reasearched and can go shopping for any extra bits and pieces and cables etc to get 2 computers connected in the shortest possable times,
Ian & Linda Jordan
Plusnet Staff
Plusnet Staff
We're currently shipping the Solwise SAR 130, you can see the Starter Pack guide here.
Thanks Dave.
If push came to shove is it possable to run one computer on the ethernet port and the other on the serial port? Although according to the Solwise info page,and feedback from the forums I should be able to use the uplink on my vigor 2200x ISDN router as a switch.
Ian & Linda Jordan
Plusnet Staff
Plusnet Staff
I don't think you can use the serial port for connecting to the Internet, this is just for logging in to the router itself via a command prompt.
Ok thanks Dave thats fair enough,I guess I can figure it out when it gets here :-)
Ian & Linda Jordan
