Quick Question-Winfax
I currently have a PC with ADSL and 56k modems using the 56k to recieve faxes in Winfax. I want to move to my newly built PC that has no 56k. Is there any way that Winfax will recieve faxes through the ADSL modem(usb)?
I suspect not, but I just want to check. Plusnets info mentions support for various types of modem but does not elaborate. :?:
No. There is no ADSL modem on the market that I have seen that is capable of using the analogue properties of the line along side ADSL.
As I thought, many thanks for the quick reply. Cheesy
Lorian
You could just sign up for a free fax to email number if all you want is to receive faxes.
https://portal.plus.net/my.html?action=myemail
