Quick Bandwidth Question
hey all
I'm thinking of getting the 2mb line with 2gb Bandwidth but i'm a heavy downloader and i was wondering if the 2gb was a monthly download limit and anything over that will i be charged?
Murray
Yes it is. You can download only a maximum of 2GB in a month, without incuring extra costs.
Extra GB's are charged at £2.00 for each adition or part GB, or if you increase your inclusive bandwidth, is charged at £1.75 per extra GB
Thanks!
Hmmm Will need to now consider the 1mb with premier Bandwidth!
Premier Bandwidth is lime unlimited?
There are no current transfer limits of 1Mb
I am also thinkling about the 2MB service with the 2GB limit. However, I though this limit referred to BOTH upload and download. Is this correct? :?
Apologies, yes. up and downstream transfer is included.
Hi, the usage monitoring is all screwed up it seems at the moment anyway. I've just received a e-mail from plusnet stating that I've gone over 3g's this month. No way, my usage is indicating that from the 11th I've only used 347mb's up until yesterday. I've raised a ticket but if plusnet charge us they can stuff it and I'll go somewhere else....
Chris
