Profiles BT Speed Test v. Plusnet
Luzern
Seasoned Pro
Plusnet aleays, from my obs 500 pver that given by BT.
This morning BT Progile 5000 Plusnet 5500. Is that nornal and why?
Plusnet Staff
Plusnet Staff
Fixes: 159
They should match pretty closely as they normally use the same data, it has been known for them to be slightly out but as long as the PlusNet one is higher than the BT one you can be confident we are not restricting the line profile.
 Chris Parr
 Plusnet Staff
Luzern
Seasoned Pro
I did not think you were. I was just curious why the two differed and if it held any significnce- good as well as bad Cheesy
Plusnet Staff
Plusnet Staff
Fixes: 159
As far as I know they should always match or at least be within 500k of each other.
Sometimes it can take our system 12 hours or so to catch up with the IP profile BT are reporting, if this doesn't update after this time then we may need to 'prod' it along.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Yep, the general reason for the difference is that the figure on the portal tracks the IP profile but reports it as the ATM rate rather than the IP rate, so for a line sync'd at 8128kbps for example the portal figure shows 8000kbps but the IP profile in the BT speedtest is 7150kbps.
