Product usage
Product usage
Can i ask probably a stupid question.
I believe my ADSL Home Self-Install - Router Starter Pack (No activation fee,
Deferred hardware cost) product is now known as PlusNet Broadband Premier
Option 1 (Monthly Contract, 1 Port Router Modem).
So looking that up on the PN broadband packages i see i have a 15GB Peak-time usage allowance
Firstly, what exactly is peak-time and what does that mean?
Secondly, how do i know what i use in a month at present?
Aplogies if this is a stupid question or the answers are elsewhere, feel free to call me all sorts if they are Cheesy
Many thanks
Product usage
peak time usage is the time between 4pm and midnight which plusnet have decided the system is most busy, which is probably true due to people getting home from work/school.
this is the time peak usage time is in effect 7 days a week
you can check your usage in a total and broken down form by going to your "Connection Settings" in the members centre and looking at the "View my usage" tool
Product usage
OK i have found the answer to my first question
Product usage
Mate thanks very much
Product usage
That clears a lot up cheers.
Lucky i works nights eh as most of my useage is off-peak!
So that means my connection will not slow as i approach my mimit as the off-peak useage does not count towards my monthly allowance. If i have read all that correctly
Product usage
correct Smiley the other hours of the day are totally unrestricted thankfully, altho some of us work till 5pm then have to go to bed to get up at 7am for work Sad
