Problems with moving from freeserve to adsl
I have a long standing connection via freeserve and a telephone link where Internet Explorer is said to be provided by Freeserve.
I recently set up a plusnet broadband connection. The adsl link has been set up but I cannot get access to it from windows as my windows me set up keeps trying to enter freeserve through IE which seems to be chained to freeserve.
What do I do to get on to plusnet?
1 REPLY
Mark_Dowd
Hi.
Only limited advice, but does it try to autodial? If so, open IE (suppress the dial attempt), then select Tools|Internet Options and look in the Connections tab. You will probably see a radio button selected to "Always dial my default connection". If so, select "Never Dial a Connection", click Ok, then close IE. It should now use the IP stack attached to your xDSL connection.
Re-opening should resolve your issue. If not, reply to this post with detailed diagnostics, and someone should be able to help Smiley
