Problems with Voyager 105
Can someone tell me if there are serious problems with the Voyager 105 and Windows XP. Ever since I got this from Plusnet I have been dogged by PC problems that have forced me to do a system recovery on numerous occasions.
My Pc doesn't want to shut down unless I do it in Task Manager, but when I remove the USB Voyager cable it shut down okay.
My Pc is only 6 months old so I don't think thats the problem.
Can anyone shed any light on this?
1 REPLY
Its likely that if you dont disconnect from the net you wont shutdown as there is active task going on in the form of updates.
If you give us some more idea what the problems are
