Problems tonight?
Problems tonight?
I've been noticing that my ADSL line if VERY erratic tonight, one second everything is fine next I can barely manage to pullin 1kb/s or any web sites. Then its working at only 10kb/s then back down to 1kb/s.
I've checked my end and it appears to be nothing wrong with my setup.
On your bandwidth test I get 436.70kbps
yep I cant even get the adslguides page to use there speed test (well goto to it once but 30mins into running the speed test I gave up)
RE: Problems tonight?
Sorry about all the posts, a product of the confirmation page not loading properly. Please ignore the others
Do some traceroutes to www.yahoo.com and www.bbc.co.uk and see if you get any packet loss. If you dont know how to read them post them up here and someone will be able to analyze them.
Chris
ok hear are some trace's I've done
Tracing route to www.yahoo.akadns.net [216.109.125.69]
over a maximum of 30 hops:
1 24 ms 23 ms 23 ms pth-rb1.telehouse.core.plus.net [195.166.128.11]
2 25 ms 24 ms 24 ms pth-se1.telehouse.core.plus.net [212.159.1.2]
3 27 ms 25 ms 23 ms pth-se2.telehouse.core.plus.net [212.159.1.3]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * 100 ms w16.www.dcn.yahoo.com [216.109.125.69]
Trace complete.
Tracing route to www.bbc.net.uk [212.58.224.112]
1 27 ms 23 ms 22 ms pth-rb1.telehouse.core.plus.net [195.166.128.11]
2 28 ms 31 ms 30 ms pth-se1.telehouse.core.plus.net [212.159.1.2]
3 25 ms 24 ms 25 ms pth-gw0.telehouse.core.plus.net [195.166.129.21]
4 25 ms 25 ms 23 ms rt-linx-a.thdo.bbc.co.uk [195.66.224.103]
5 27 ms 25 ms 26 ms www12.thdo.bbc.co.uk [212.58.224.112]
Trace complete.
Tracing route to www.adslguide.org [80.249.96.41]
1 25 ms 23 ms 23 ms pth-rb1.telehouse.core.plus.net [195.166.128.11]
2 24 ms 24 ms 25 ms pth-se1.telehouse.core.plus.net [212.159.1.2]
3 25 ms 24 ms 24 ms pth-gw0.telehouse.core.plus.net [195.166.129.22]
4 24 ms 25 ms 25 ms linx2.lon3.as8553.net [195.66.226.126]
5 26 ms 25 ms 26 ms bdr1-gw.thdo.ncuk.net [80.249.97.9]
6 26 ms 25 ms 32 ms ir1-gw.thdo.ncuk.net [80.249.97.12]
7 27 ms 26 ms 27 ms iota.ncuk.net [80.249.96.41]
Trace complete.
As you can see the yahoo test I wasnt able to get anything though all of a sudden it came back and a few mins from now it will do the same again.
