Problems?? is it just me?
is ne one else having the problem of no traffic for about 2 mins occouring every 1/2 hour or so?
this really F**ks ne Multiplayer :kill: Games, as i have to wait for some time or reconnect!
Could this be a hardware prob with my system or could the prob with +net?
RE: Problems?? is it just me?
No it's not just you. I dont use the net for gaming but I am also noticing that my system freezes on occasions for about a minute or so.
If you look at the service status page you will see that Plusnet have identified the problem and are going to do a "fix" on Friday, and a proper repair in December.
Regards
http://www.hmrg.co.uk
I think basically we are all suffering this. But it gets worse. For me now and then I lost the adsl connection and the only thing I can do is power cycle the adsl router. Plus net have known about this since 16th of November - through "Contact Us" - and so far have not done a darned thing about the problem. :angryfire:
> Regards
> John
it's happening to me too, very annoying but at least the speeds are fixed!!! Cheesy
I've also had this about a min after i logged on this morning i had to log off then log back on, really big pain.
thanx guys, ,your comments have now put me at ease.
chino
yeh i get this too...
however i foundif u just leave it... it will be fine in about 1min however if you discconnect your have to wait for a long time to try and reconnect..
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
Well guys when those CD/ACT lights start their alternating flashing I can wait and wait and wait. Or I can power cyle the router and things are fine.
> cUnDaLl
Since the recent 'upgrade' I'm finding the same problem. I'm finding no response from webs sites or apparently being disconnected from online games. It's just momentary and if I check my router it tells me that I haven't necessarily been disconnected (connection was lost 3 times in 48 hours, I've been booted out of games server 6 or 7 times in the same period).
Of course on a MMORPG like Everquest I then need to wait a couple of minutes before I can log back in to the server and may well find that my gaming efforts have been set back by hours because of this glitch.
So much for my 24/7 connection I may as well be back on isdn where at least I can choose to pay more for a genuine 24/7 service or go for something cheaper and accept a 2 or 4 hour cutoff as opposed to a random cutoff.
If these problems persist then I'm afraid I'm very likely to be jumping ship and looking for a more reliable provider.
Been using 'All seeing eye' to find games on line, counter strike mainly. I have noticed on a few occasions the connection will hang. I don't think this is just a Plusnet problem, as I play against my cousin who is on BT and his connection hangs at around the same timeHuh?
*crying*
Had this for a couple of days now and first tought it might have been my dodgy USB modem (Alcatel).
It's still horrid. The line drops every 10/20minutes,and sometimes even every 60sec!
Also had prob's with the DNS (yet again, or shall I say 'still'?). Changing to a more reliable DNS fixes this (apart from loosing the connection altogether).
Dunno, maybe it's a 'bad IT' month or summin and nobody told us about it? I work in IT (support and maintenance) and there are a lot of peeps out there who have all sorts of trouble (more than usual)... .
Well, it's almost XMas and I shall be wishing for a reliable ADSL connection this year (pity about the new G4 I originally wanted)... but then, you can't have everything now, can you?
Merry XMas time to ya all 3:=)
Axel
