Problems dowloading in Kazaa
When switching over to broadband today I was unable to download any files from Kazaa
The message either says "connecting" or "more sources"
Has anyone had similar problems and do you know how to fix them
thanks
RE: Problems dowloading in Kazaa
> thanks
> tried kazaa myself and had no problems the only thing i will say is if your on adsl you still can only download data at the speed of the other computers modem and if there allready is a download going on from it,it will slow your connection to it down,i'm not much help but it is something to be aware of,good luck
> > thanks
> i cant even get a connection
> thanks
The ADSL Home Surf account does not allow peer-2-peer traffic such as Kazaa or access to Usenet binaries. The ADSL Home self-install account does support this which you may upgrade to if required.
Regards,
Robert
| Robert Kelly........................Unmetered & ADSL solutions
| Customer Support...........................for Home & Business
| PlusNet Technologies Ltd...............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
