Problems connecting iRAS through VPN enabled ADSL
Sad Sad Sad I'm trying to connect via iRAS through VPN enabled adsl line and not able to and not suceeding. Using D-link 614+ wireless router and guess that the router set-up is wrong in some way. Can anybody offer any advice?
1 REPLY
Might have a few ideas
Basically I need to know how you are set up
e.g
are you using a USB modem ?
Ethernet ADSL Router ?
if so are there any other machines on you home LAN
Are you using one or more Static IP Addresses.
Kind Regards
Marcus
