Problems conecting since being moved to LLU
ToeKnee
Since being moved over to LLU 2 weeks ago my modem has a problem re-synchronising with the line (DSL light is flashing) after switching it off then on again.
It has re-connected a couple of times after being disconnected for half a day or longer and once connected the connection is fast and stable.
When connected my modem indicates 8160k/s downstream and 544k/s upstream.
When I was connected via BT IPStream my modem ALWAYS re-connected within about 30 seconds and I had a stable 2Mb/s connection.
My modem is a Linksys ADSL2MUE which is capable of speeds up to 24Mb/s so 8Mb/s should not be a problem.
The line stats measured from the exchange by Plusnet/Tiscali are:
InterfaceName: Adsl3/0/9
Current Profile: a8160u896i8a
Alarm Profile: ALARM-PROFILE-1
Line Coding: 2
Line Admin Status: Up
Sync Status: Circuit in Sync
PPP Status: PPP Session Present
Session Id: 33626
Downstream SNR: 14 db
Donstream Attenuation: 41.5 db
Downstream Status 0x8000
Downstream Output Pwr: 18.8 db
Downstream Current Rate: 8160 kbps
Downstream Interleave Delay: 8 ms
Downstream CRC Block length: 17340 bytes
Upstream SNR: 14.5 db
Upstream Attenuation: 19 db
Upstream Status: 0x80
Upstream Output Pwr: 12 db
Upstream Current Rate: 544 kbps
Upstream Interleave Delay: 4 ms
Upstream CRC Block length: 1156 bytes
Can anyone think of a reason why I am having this problem?
