Problem with ADSL500 USB modem
HELP!
I have a Binatone ADSL500 USB modem and every time I log the PC off the settings are lost and then upon start-up it recognises the modem as new hardware and I have to re-install the driver.
I was running Windows ME and had this problem, now running XP and the problem has not gone away - could it be a duff modemHuhHuh
Cheers in advance
Phil
UK Shops on the Net - The easy to use shopping directory
First off, when moving to XP, did you use the upgrade method. If yes, then this is a possible problem.
Xp tried to migrate settings when upgrading, which means old issuie may still be there, or new issues could arrise from incompatable settings.
Once the modem is insteadd, I would advise a forced uninstall via device manager.
Unplug the modem and reboot twice, which should clear things fully. Then try plugging in against and re-install the drivers.
