Problem loading certain pages
May i say i have great service from Plusnet, but i have a problem. I don't think it is connected to the ISP, but perhaps someone here can help.
Recently i have been unable to access certain websites via both IE and Firefox, namely php-fusion.co.uk, and livejournal.com.
I've cleaned my dns cache, deleted all my cookies, history and temps - even reinstalled both programs. But to no avail.
While with IE i get the 'page cannot be displayed' blur, firefox tells me my connection was refused.
These sites don't use flash or java (i think) which may cause issues. What could be wrong?
Regards,
CK
Alecto
Both load fine for me.
Try a tracert to see how far you're getting.
I had similar issues with certain website and it was an issue with my MTU settings!
Ray
MTU settings?
Are you running through a router or an ADSL modem connected to your PC?
There is a utility within Plusnet tools to optimise your connection.
Ray
The adsl modem they supplied
There is an announcement on this forum relationg to MTU and is worth a read.
If you are using the supplied modem, there is a free utility avaialble for download call DrTCP.
You will find it through Google
Ray
Hey,
Ive just tried the tracert idea with livejournal. The end of the reply came back as (nopte, hops 1-10 are seemingly fine):
Hop 10 @ border9.ge6-1-bbnet2.sef.pnap.net. 0 miles [+0]
Hope 11 @ [Destination Unreachable] livejournal.com. 0 miles [+0]
Hope 12 @ [Unknown - Firewall did not respond] -1 miles [+0] 0 miles [+0]
Analysis:
Last hop responding to ICMP: 11, UDP: 11, TCP: 11.
There appears to be a firewall right after 66.150.15.150 (hop 11) that blocks ICMP, unwanted UDP, and unwanted TCP packets.
Does this help me at all, knowing this? What does it all mean?
holdtight
This is what im getting and all seems fine both sites load ok for me in both IE and firefox
Tracing route to livejournal.com [66.150.15.150]
over a maximum of 30 hops:
1 15 ms 14 ms 17 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
2 14 ms 14 ms 15 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
3 14 ms 14 ms 14 ms 195.50.117.169
4 14 ms 14 ms 14 ms ge-1-0.core1.London1.Level3.net [212.187.131.13]
5 15 ms 15 ms 15 ms ge-5-0-0.ar2.LON3.gblx.net [208.51.239.161]
6 175 ms 174 ms 175 ms so0-0-0-2488M.ar4.SEA1.gblx.net [67.17.71.206]
7 160 ms 159 ms 160 ms InterNAP-Ken-Schmid-Seattle.ge-3-2-0.ar4.SEA1.gb
lx.net [64.213.33.230]
8 159 ms 158 ms 159 ms border9.ge6-1-bbnet2.sef.pnap.net [63.251.160.83
9 161 ms 161 ms 160 ms livejournal.com [66.150.15.150]
It has been suggested by a friend that i should tyr connection to a different dns server.
Would this help, and how do i do such a thing?
Aha. The answer was so simple.
Perrguardian was set to block a number of somewhat important ports from passing information.
Turned off that particular setting, and all works fine Smiley
CK
www.dialectic.org.uk
Glad you sorted it in the end!
Ray
Cheers Smiley
Thanks for your help and suggestions.
CK
