Probably another daft question?
I have applied to be regraded from 512 to a 1 MB connection. the fee has been taken from my account but on checking my number with the BT and one other site, the result says that I am too far from the exchange for a 1 MB service.
Does this mean I am refunded if PlusNet find this is so?
Cheers
Yes you will be refunded the upgrade charge. The limits are being changed on Sept 6th, so re-try then and you might find that you can get 1MB Cheesy .
Aaron
or just raise a ticket saying if it fails now, to retry after 6th. Saves on the admin of a refund and repayment occuring. PlusNet will then just put your request on hold until after 6th and resubmit your request.
Cool
Cheers
