Prob with old style phone!
Hi all,
We have 2 extension boxes from our BT master box, both fitted with splitters, which work fine. However there is a old style phone (the one where u turn the dail) that is directly connected / hardwired to the BT master box which rings fine and you can hear the caller speak but the caller cannot hear you. Is this a likely problem to do with my new ADSL connection (self installed)Huh?
MoMo/
1 REPLY
RE: Prob with old style phone!
> Hi all,
> MoMo/
You can soon find out by unplugging all the ADSL splitters and see if the phone then works properly.
If it does then you will know the cause.
Regards
http://www.hmrg.co.uk
