Premier or Plus
Premier or Plus
I have just been regraded to 2mb, and as it happens, I am actually getting good 2mb speeds Cheesy
I was looking at the Broadband Plus packages (I am on Premier at the moment) and it looks very tempting to downgrade.
I mainly use the net for surfing and email, although I do quite often bulk download quite a lot of web content for later browsing offline. I sometimes use P2P, but only for the odd file.
So would I be better off on the 14.99 Plus package than the 21.99 Premier?
The only differences I can see between the two are:
P2P throttling at peak times, which doesn't really affect me.
The amount of webspace 100mb vs 250mb, not a problem for me.
and the PRICE, over a fiver cheaper each month.
Please could someone tell me if I have mised something obvious, Are there any other limits, differences?
Will my bulk web downloading be throttled on Plus? it is all HTTP traffic.
Thanks for reading, and any advise.
Stuart
1 REPLY
Alecto
Premier or Plus
They may throttle your bulk downloading if they feel it necessary, but it sounds as though Plus would do for you.
Why not try it - you can always upgrade to premier for free if it doesn't work out ?
There have been a number of people posting on here quite happy with it.
