Premier: Another Speed Case
Your current broadband speed is 1000 Kbps Cry
I've let everything go cold several times over the last 48hrs.
Netgear Router
2 x OS X (Wireless) + Airport Express
I x openSUSE (Cabled)
Booted everything back up in the text book order.
No change.
try visiting http://speedtester.bt.com/ and post your details so someoen can help you, i have the exact same problem
donj53
Good luck dayweavers.It has taken me a new router,no extensions and umpteen messages to finally get it sorted.Run the speedtester from BT and if it says your connection should be higher then send the two results to plusnet ie what BT say you should get and what plusnet say you should get.
