Possible DNS problem? cant connect to my webspace directly,
I am having problems connecting to my webspace server (not plusnet) the address of my site is http://www.funkybands.co.uk
The website no longer shows up and I cant even ftp into it, it was working fine yesterday but now wont work!
The server itself is up because i am able to ftp to it using the shell account on my plusnet cgi webspace.
I just cant connect to it from my pc directly. any ideas?
Just tested it and its up and I can get on OK.
Can you connect using a IP? Check your host file for anything which may stop it. Try a diffrent dns server try 194.119.131.66. can you ping it by name or ip?
cant seem to connect via ip either, when i ping it says
Pinging funkybands.co.uk [209.51.158.106] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
whats this 'host' file i need to check? not heard of that!
This is what i get if i do a trace route
Tracing route to funkybands.co.uk [209.51.158.106]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.8.1
2 19 ms 19 ms 19 ms lo1.plusnet.pth-ag2.plus.net [195.166.128.6]
3 19 ms 19 ms 20 ms gi1-2.vlan3.pth-gw4.plus.net [212.159.1.3]
4 20 ms 19 ms 20 ms gi5-0-4.pth-gw1.plus.net [195.166.129.21]
5 20 ms 19 ms 19 ms cr02.ldn01.pccwbtn.net [195.66.224.167]
6 108 ms 108 ms 106 ms pos5-3.cr02.atl01.pccwbtn.net [63.216.0.26]
7 106 ms 106 ms 108 ms webusenet.ge3-0.4.cr02.atl01.pccwbtn.net [63.216
.31.138]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * *
Could be a routing/DNS error. Have you tried the old "reboot all equipment" answer or, if your using Win2000/XP goto command prompt and enter :- ipconfig /flushdns
No problems accessing the web site for me.
yup tried rebooting all equipment, even just tried bootinh another OS and still the same problem Sad
Well I can access it fine.
What equipment are you using, USB modem or router ??
When rebooting all equipment, including router, it is better to wait 10 minutes or more so as to possibly get a different VP and to kill the session at the exchange.
Using a 4 port ADSL router+switch connected to my 3com NIC.
I'll try disconnecting the router for 10mins and try again. Seems strange that all other sites seem to be fine, just the one i want to use!
Im wondering if my own server has banned me! hehe
In a command prompt window try typing ipconfig /flushdns - which will clear out any DNS records. It's possible your computer cached a bad record for that site.
tried the flush dns command and still the same problem Sad
OK, so you have rebooted (after 10 mins), flushed DNS recoreds, tried a different OS, cleared the route table in router but everyone else appears to be able to access the site !!!
Well, I can only suggest that this is one of these Internet quirks and I would leave it for at least 12hrs to allow any routing to change. As with your router, routers along the path can also have bad DNS records.
I assume you wanted to update something on the site, hence the initial "can't FTP" question.
yup i need to update another site that is on that server for a project Sad
ive managed to connect to it via a proxie but its really slooooooooooooow. Hope the problem sorts itself out soon!
