Port Forwarding
Port Forwarding
Just got connected with Plus premiere adsl. Using a Thompson Speedtouch 510 router - anyone have any idea how to forward some ports using this router?? i can't play City of Heroes!!!
Port Forwarding
log into the routers web interface and look for PAT / NAT / Address translation and then just set the ports to your internal IP (make sure it is static)
buz
Port Forwarding
to get my ip am i right in thinking i type cmd into run and then type ipconfig in the command prompt?
is the first set of numbers my ip?
i'm on premier with plus net does that mean i have a static ip?
Port Forwarding
Your static IP address will be the address of your router. Your PC IP address will probably be something like 192.168.0.1
Port Forwarding
it shows:
ip ad:10.0.0.1
is that the static ip?Huh
Port Forwarding
No, IP addresses starting with 10 are internal/private IP address.
Port Forwarding
so how do i find what it is then?
Port Forwarding
Open this URL in your browser ... www.whatismyipaddress.com
Port Forwarding
cool i've got it now cheers
and this is what i should be forwarding ports for?
