Port Forwarding on Plusnet Router
Can someone tell me if there is a way to get the Port forwarding working on the Routers plusnet supply.
I fill in all the bits and save and restart but it doesn't forward the ports!!! mmm starting to wish Id bought a D-Link one now!
1 REPLY
RE: Port Forwarding on Plusnet Router
I've got it to work fine (at least for the port Unreal uses).
Make sure you specify TCP and UDP in the protcol box, enter the same port in both boxes under port number (I presume you want e.g. port 80 forwarded to port 80 on one of your PCs), and the IP address of the PC you wish to forward to on the right. (for me, this is 192.168.8.2).
Worked for me.
