Poor speeds since upgrade
I have been upgraded but I am on the outer limit of the exchange. My pre upgrade speed tests were around the 1000kbs mark, then after I got a 2476kbs and thought whoppee. This joy was short lived as my range now is 200 to 500. When a go through the spped fault checker here it says RED line contention but that cant be the case as it said that at 6.30 am today as well. Any thoughts on the problem and posible solutions
It is likely to be a problem at your exchange. If you go to:-
http://usertools.plus.net/exchanges/
and input your telephone number or exchange name then it should give you more information.
Hopefully it will give you an estimated date for BTw to have fixed the problem.
Thanks for the tip, this is what the site said,
BT is reporting that some of the virtual paths at this exchange are not operating within BT Wholesale's planning guidance, although they are still operating within the product specification.
At busy times, your ADSL connection may operate at a reduced speed, although not all customers on your exchange may be affected. You should only contact support if there is no current ETA date set.
The ETA fix time is: 09 Dec 06
Record last updated: 04 Dec 06
Dum de dum still waiting for green light.
The ETA fix time is: 28 Dec 06
Record last updated: 11 Dec 06
What does it all mean.HuhHuhHuh?Huh
