Poor speed test results...
Today after getting the feeling that my broadband was running slower than usual I used the speed test in "connection settings" and my 512 connection only managed 302, I tried it a few more times but it still only managed to achieve 405. I was wondering if plusnet was busy at the moment or if the speed problem was at my end. I usually get speed tests of around the 490 mark and was suprised to get 302...
P.s ADSLGuide.org.uk gave my connection 343 Kbps Sad
Have you tried reconnecting?
There was a problem this afternoon that cuased connections to become congested. It now take 24 hours or so, for people to reconnect and balance things out again.
Thanks, it's sorted now at 480 again Wink
Very slow connection speeds help
Cry I have a 1Mb connections but when i tried the speed test i was getting 415 kbps today. Normally get 950 help. tried rebooting and switching on off the router no joy Sad
Just unplug the modem or router phone cable from the socket for 10 seconds and then put it back again, this should put you on a different pipe, if you see no change, keep doing it until it works (it can take 5 tries or more) No need to reboot.
