Poor performance since install and getting worse
Asked to post results of traceroute/ping test here, so here they are - if anyone can help me I'd be really grateful!
Traceroute Results: View Traceroutes
Traceroute Time (24 Hour): 16:19 to 16:30
Traceroute Duration: 11 minutes
Traceroute Packet Size: 64 bytes
Packetloss in Traceroute?: Yes
Exchange: pendleton
Problem: Permanently Slow Data Transfer (Everything is slow)
Duration of Problem: Since installation
Minimum Speed Achieved On PlusNet Speedtest: 76 kbps
Maximum Speed Achieved On PlusNet Speedtest: 150 kbps
Average Speed Achieved On PlusNet Speedtest: 113 kbps
Account: ADSL Home (Self Install) - 512kb (50:1)
IP Block Size: Single (default)
Ticket Number: None
Additional Information: can\'t download mail - can\'t find pop server - have checked name pf server is correct and it is - ticket logged for all of this earlier today - fyi i have previously failed to download winmts but did it just now on 4th attempt - most web pages are v slow to load but some come back quick - for example did a google search and the home page and results were displayed almost instantaneously - but bbc and plusnet are really poor - also tried dslreports.com/tweaks but can\'t run test as file download times out v quickly - hope this helps identify the problem area - many thanks Sad
Also, when look at dsl stats on router (solwise 11) it shows significant errored seconds, severely errored seconds and unavailable seconds. And... when i run diagnostics from the router the final 3 tests a) ping primary domain name server, b) query dns for globespanvirata.com and c) Ping www.globespanvirata.com all fail - but not sure if these test are valid or not anyway!
How long has it been like this for? Do you get noise on your line? have you checked your setup with the tutorials ?
ADSL Trouble Shooting :
http://portal.plus.net/central/forums/viewtopic.php?t=9565
ADSL Wiring
http://portal.plus.net/central/forums/viewtopic.php?t=9996
ADSL MTU Tweaks
http://portal.plus.net/central/forums/viewtopic.php?t=12116
Aaron
PS you've posted the same item twice. You might want to ask the forum admin people to close it.
csogilvie
Duplicate removed.
