Poor BBCi framerates
michaelscott
BBCi just seem to have got the new range of +net IPs (one of which I use). But the picture only updates every few seconds despite playing at 250kpbps. I got higher framerates when it played at 32kbps!!
Is it normal for the picture to update so infrequently?
Mike
I had the same problem and it related to a corrupt DLL file. RealOne never detected the corruption and attempted to use it regardless.
This left the picture choppy but the sound perfect.
To solve this, I had to perform a full uninstall of RealOne, however, not using the normal uninstall utility.
Real provide a utility that will strip almost every component of RealOne out of your system. This is rare for a company. It will however, keep a copy of your music library database (by request).
To use this utility, navigation your your installation drive.
Move to throught the following folders
Program files
Real
Realone player
Setup
In there you should see a utility called ".r1pclean.exe", or with .exe missing
Run this utility.
michaelscott
Cheers! It works perfectly now Cheesy Cheesy
