Plusnet Speed Profile Update
karmi
I now sync at 8128 to the exchange, 7150 lineprofile (the max?) with BT at longlast and have a stable connection.
Is it possible for you to bump the profile up at your end manually to the maximum, as I had before, 8500 I believe.
Cheers.
James
I'm not seeing you as being onto the 7150Kbps profile yet, but BTs systems might just be catching up with each other. I've set your PlusNet profile to 8000Kbps, which should result in you seeing an improvement in speed following a reboot if BT have indeed changed your IP Profile.
karmi
Nice, reporting 7,21mb on Speedtest and a download test at 918k a second. Not bad for ADSL.
Many thanks Smiley
James
*mutters something rude about the Sheffield Cutler exchange*
